Nitrous Tune vs Regular tune??
Old May 7, 2005 | 02:44 PM
gabez28's Avatar
Hey guys I have a tune from PCM4less with the unlimited tunes option. I was curious whats involved or changed in the nitrous tune if I got a wet kit installed.
Old May 10, 2005 | 09:54 PM
jdizzell's Avatar
Re: Nitrous Tune vs Regular tune??
Timing needs to be retarded.
Old May 11, 2005 | 01:21 PM
Don't change your PCM tune for nitrous. Adjust the A/F ratio on nitrous using the jet sizing in your wet kit. And use an external retard box to pull the required timing ONLY when you spray. Why screw up your NA performance by altering a good NA tune? You'll lose performance when you aren't spraying if you do that.
DirtyDaveW
Dec 1, 2016 05:37 PM
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
MadMav
May 25, 2015 09:35 PM
bandit383lt4
Dec 21, 2014 09:12 PM
