Need help with datmaster
Old Oct 2, 2004 | 08:17 AM
wicked_95z's Avatar
I can monitor data but when I try to record no data is present on the laptop but it says its recording? Any help?
Old Oct 2, 2004 | 09:17 AM
Alvin@pcmforless.com's Avatar
Re: Need help with datmaster
wow, I would try a reinstall.
Old Oct 11, 2004 | 05:51 AM
jonota's Avatar
have you enabled autologging?
Jonota
Old Oct 11, 2004 | 09:07 AM
wicked_95z's Avatar
I havent changed anything since install
Old Oct 12, 2004 | 06:39 AM
jonota's Avatar
with datamaster, to be able to actually record a file and recall it you either have to make a file (complicated) or enable autologging, which will automatically make a file for you when you press the record button. Check into it in the help file of datamaster
Jonota
Old Oct 19, 2004 | 07:43 PM
wicked_95z's Avatar
Okay, finally had time to mess with it and still nothing. I tried a reinstall, I enabled and disabled autologging. I can however take a single frame recording but no continuos recording and it still says recording data at the bottom of the data screen. Here's how I try to record.
Open data master-go to file and to record aldl data- on the data acquisition screen I open a new file and give it a name and hit enter. And nothing. I have to assume my cable and port are good cause I can monitor and read my pcm with tunercat. Any help would be great cause I think I have a real problem but cant datalog to findout. Left o2 sensor is reading 78mv on single frame
Old Oct 19, 2004 | 07:48 PM
jonota's Avatar
Here:
Open datamaster
File->Record ALDL data
If recording is not on, hit the button to turn it on
If autologging not enabled, enable it OR make a file name
In the bottom left (sample control center) you must hit START to begin recording
When done recording, press stop. Top bar of the window will tell you the file name for reviewing it later.
Jonota
ENRKyle20
17
Aug 13, 2009 05:14 PM
wicked_95z
Jun 1, 2006 02:28 PM
Guggi97_RA
Jul 21, 2004 09:39 AM
lt4 fd
Jan 2, 2003 11:00 PM
