My '95 camaro z-28 will not start
Old Nov 27, 2008 | 09:55 PM
rokbrigade's Avatar
Unhappy My '95 camaro z-28 will not start
I have a '95 Camaro Z-28 with a freshly built 383 Stroker. My problem is my car will not start at all! I put a brand new battery, the lights all come on but the engine will not crank at all. When I turn the ignition key all I get is a faint click of a relay making contact and that is it. I do not even hear the fuel pump turn on, and
the battery gauge does not even move period. I would deeply appreciate it if someone can give me an idea of what this problem can be.
P.S. I checked the voltage at pin #30 (PCM Ignition Feed Circuit) and I do not get voltage. I also checked voltage at fuse #5 and there is nothing. I do get voltage at pin # 31 (PCM Battery Feed Circuit).
Old Nov 27, 2008 | 10:33 PM
ak95ta's Avatar
Pull the fuse and check to see that the pins havent gotten pushed down to where they arn't contacting the fuse. Ive seen it before thats why im posting.
Old Nov 28, 2008 | 08:21 AM
95Blackhawk's Avatar
There are 2 batt feeds and 2 ignition feeds into the PCM. Must check them all. GL!
ChrisFrez
Dec 7, 2014 06:01 PM
CamaroZBoy
Aug 16, 2002 10:03 PM
PaulN64
Aug 8, 2002 05:39 AM
PaulN64
Aug 7, 2002 06:17 PM
94m5
Aug 7, 2002 11:59 AM
