Moding aftermarket TB to get equal left/right BLMs
Old Oct 2, 2002 | 12:33 PM
Crazy Man's Avatar
Anyone know of any links/or info to show what is needed to make these after market TBs moded to allow idle air flow in the idle air passages when the TB blade is closed?
Without this most stroker engines do not seem to get equal left/right blms
I have a BBK/Edlebrock 58mm TB.
Old Oct 2, 2002 | 02:10 PM
lateapex's Avatar
Try http://para.noid.org/~lj/PCM%20Tutor...litBLMinfo.htm
I am borrowing a scan tool this weekend and hope to follow his instructions. I have an OEM bored out 52 mm TB, so I propably don't have the problem he talks about fixing mechanically.
Bob Bishop
Old Oct 3, 2002 | 09:49 AM
csabatka1's Avatar
What are your BLMs btw? I'm seeing r- 154-160/124-128 - l at idle and partial throttle.
Old Oct 3, 2002 | 10:19 AM
Crazy Man's Avatar
My BLMs are usually about Maybe 2-6 split at partial throttle.
At idle they are about the same but if my exhuast gaskets start to leak they get really wide split in the 140-160 range.
I want to have them almost deadon.
Old Oct 3, 2002 | 08:15 PM
Dave 96TA's Avatar
Shawn, which exhaust gaskets are you referring to? Header or collector? I just installed new O2s this evening and took it out for a scan run, my INTs are pretty split (by as much as 17 at the worst [114L, 131R]) at random for the most part. I did just install a new collector gasket on the passenger side tonight (the 2 month old Mr. Gasket piece fell apart) and I'm wondering if these numbers are telling me the other one is leaking too... You cannot hear a small idle leak over the exhaust so I'm looking for digital proof :\ My BLMs are split by as much as 9 but are mostly within 4 or 5. I dont think its had long enough to learn those values yet, I reset the BLMs just before running out to scan.
Old Oct 4, 2002 | 07:50 AM
Crazy Man's Avatar
The header collector was leaking.
I have SLP shorties on my T/A and the donuts go on me every 6-9 months. Quite a pain actually. You can usually tell when there is an exgaust leak before the O2s when the engine runs leaner. At least that is what I was seeing.
It would be a good idea to check for leaks in you have a split BLM.
Old Oct 4, 2002 | 10:54 AM
Dave 96TA's Avatar
While I dont imagine the collector gaskets would have any effect on my O2 readings (since the O2 bungs are welded in 5" ahead of them), the header primary seal might...pretty sure i've got a loose bolt there. After installing the new collector gasket and quieting that part down, now I'm hearing a small leak at idle right behind the alternator. Will have to check it out.
I plan on scanning the car this weekend and tuning it a little more lean (than stock) where necessary.
Old Oct 4, 2002 | 12:05 PM
Crazy Man's Avatar
On my SLP headers, one side has a donut gasket before the O2 sensor and the other side has it after...
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
CARiD
Sep 30, 2015 05:44 AM
drt
Sep 27, 2015 04:39 PM
autoxr166
Sep 25, 2015 04:21 PM
MDZ28
11
Sep 24, 2015 09:15 AM
