Measuring timing with opti/LTCC
Old May 7, 2004 | 01:19 PM
mtxpert's Avatar
When dyno tuning I've found it very inneficient to do a dyno run, upload file, run, upload etc when adjusting timing.
My suggestion is this:
Using the LTCC I will apply the trigger to cause the timing retard function to enable and pull 2 degrees (starting high in the program) and then make a run then 2 more etc.
Once I get it to the point where I have peak HP by timing then upload a file with the same reduction.
My problem is two fold:
1. Last time I ran at the dyno and uploaded new tunes, datamaster showed no differences in the timing causing great confusion.
2. How can I accurately measure timing so that I know where I should be at in my tune?
Let me know,
Mike
Feffman
Oct 9, 2015 05:42 AM
ddr698
Jan 31, 2015 10:58 AM
Jul 4, 2005 05:00 PM
1LEThumper
Jul 14, 2003 12:45 PM
