MAP and TIMING....what do i look for
Old May 16, 2004 | 09:12 PM
97Z-M6's Avatar
when using datamaster what do you look for to udjust timing. is there something i should look for or what.
if i put a cam in my car how will i know to add timing and where to add it.
JUST TRYING TO LEARN A LITTLE MORE.
THANKS
Old May 23, 2004 | 01:31 AM
roadtrip120's Avatar
Data master is a read only program.
It will tell you the spark advance.
As far as changing it when you get a cam, you will need lt1 edit or tuner cat.
Just have someone else program the pcm for the cam, if it is common, JMO.
Old May 23, 2004 | 08:34 AM
97Z-M6's Avatar
i have tunercat but im asking what to look for.
becuse i cant get the map below 50 at idle on a 230/ 236 cam
Old May 23, 2004 | 08:47 AM
Dan K's Avatar
Try more idle rpm, try different IAC settings, and more or less closed TPS timing.
Old May 23, 2004 | 05:34 PM
97Z-M6's Avatar
the closed tps timing is 38. the iac counts are 43 in open loop and 76 in clossed and with the ac on they are 107
so whattable do i lower or raise.
Old May 23, 2004 | 10:57 PM
Dan K's Avatar
Are you asking about timing in general, like your first post indicates?
Or have we moved on to just trying to raise the idle vacuum like your second post is asking?
Or both?
Old May 24, 2004 | 11:57 AM
PoorMan's Avatar
I don't thing anyone here can give you a "do this" answer on this.
Old May 24, 2004 | 04:19 PM
97Z-M6's Avatar
well both kinda
if i have a stock car and i through in a healthy cam.,and i look on datsmaster as i scan it. what would indicate where i need to add timing, not at idle but all across the board.
the other question was kinda for a freind i can see to get his map down below 56 at idle. and the blms are split at 116 and 125.
Old May 24, 2004 | 07:53 PM
Dan K's Avatar
There really isn't anything that you can look for as far as knowing what to do with timing.
I will tell you this, with the cars/cams that I've done I haven't strayed much from the stock timing table. A couple of degrees in the lower rpm/map areas.
The only other thing is to shift the table to the right. From what I've seen is given the same conditions, a larger cam is going to have a higher map at part throttle conditions.
With the blm split and idle map, keep trying different rpm and closed tps combinations. If it is a 230/236, what I've found is 950-1000rpm and 30-32* to be the sweet spot.
I'd have to look to see if I can find that datalogs to see what we ended up with as far as map/vacuum.
SEOJustin
Sep 24, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
4586
Aug 18, 2015 07:08 AM
FredM
Aug 14, 2015 01:49 PM
Amshnock
14
Jan 18, 2015 11:47 AM
