Manual fan switch help
I have a 96 T/A that I what to put a manual fan switch on.
I converted the car to OBD1 a few years back and all is well.
I been looking at the wiring schematic instructions from shbox.com
http://shbox.com/1/fan_sw_diagram1.jpg
This where I'm at with this, because I have converted to OBD1
I should use the OBD1 instructions. Yes/No
I tested terminals H and J without the car running this afternoon
using my Powder Probe by applying ground.
This is what I found.
Ground terminal J "low speed" both fans run on low.
Ground terminal H "high speed" only one fan runs on high,
"the passenger fan"
Ground terminal J and H and both fans run on high.
Is this how this system should work? Ground J and H for both fans on high?
"the passenger fan"
Prominent Member
Re: Manual fan switch help
Yes. You have discovered the medium air flow speed with terminal H alone, that isn't used by the pcm. Most folks don't know it exists.
carguyshu
Jan 22, 2017 11:19 AM
slothgrant
Aug 22, 2002 03:01 PM
