making a cable, how to test
Old Sep 2, 2005 | 07:23 PM
snakethis69's Avatar
i made the max2332 version of andrews cable and it worked. surprisigly. but now a few friends want cables and i am tempted to try the two resistor theory as it will be way quicker. is there anyway to test these using the db9 and some program thanx guys.
Old Sep 3, 2005 | 11:00 PM
SUTTERERMAN85's Avatar
Re: making a cable, how to test
i am interested in making a cable for my car, i am sorry that this is off the post but where did you find out how to make it? and how much did it cost? a link would be great. thanks in advance.
nick
Old Sep 3, 2005 | 11:20 PM
very simple actually, well one of them. the MAX is a complicated version, i will try and find the links for you. cost was about 6 bux, but i didnt get the OBD connector. i just used 3 pins
Old Sep 4, 2005 | 12:25 AM
Z95m6's Avatar
If you are asking if there is a way to test the cable, just read your pcm. If it reads fine then go a head and flash it. If you are saying you are just using 3 pins plugged into the port then i think you are asking for trouble. If one pin falls out during programing i think you'll fry a pcm.
Old Sep 4, 2005 | 10:08 AM
no, cause the pins are long, they stick in pretty far and are very snug.
Old Sep 4, 2005 | 10:13 AM
i cant find the 2 resistor schematic but the MAX232 can be seen at http://www.akmcables.com/assembly.htm and i have the schematic if needed. i actually have the schematic for both on my site.
Old Sep 4, 2005 | 10:43 AM
i would like to find the 2 resistor version. i have know about the akm site and how make than one, but there is a lot involved. i bought one from aldlcable.com (i think that is the site) and its pretty cheesy. it pretty much has just 2 wires from the obd 1 plug and cig lighter plug and then the serial port. i cant get tunercat to work and datamaster is intermitten when i reads. it has to re sync like every 3 seconds. i am wondering where the resiosors go and mabey that is me problem. i looked at your site and didnt see the plans for the cable. thanks again
nick
Old Sep 4, 2005 | 11:31 AM
http://curtiscomputer.servebeer.com
andrew will fix his cable for you, he helped me threw making mine. i am sure if you get ahold of him he can work something out.
Old Sep 4, 2005 | 09:45 PM
StickMaster's Avatar
whats the 2 resistor thing??
lol @ the pin comment...all i have are wires i jam in the aldl connector about 20 flashes with no problems
why do you have 3 pins? i only plug in 2 to the ALDL..
and yes to test i would just read the pcm
Old Sep 4, 2005 | 11:23 PM
i use the +12 from the connector vs the lighter
Old Sep 4, 2005 | 11:24 PM
the two resistor thing will fit inside the DB housing. eliminating the need for the max232 board. i havnt used it yet but i am hopeful it works. going to test it tomm by reading PCM
Old Sep 6, 2005 | 02:24 PM
limige's Avatar
i bought the kit and put that max one together and it didn't test out right using comunications thingy like it said, haven't gotten a chance to try it on a car yet, double checked all solders and reheated them to make sure there were no cold solders, still won't test out right...
edman
Jan 25, 2015 02:41 PM
NewsBot
Dec 3, 2014 12:30 PM
naaz90
Jul 27, 2002 08:22 AM
