MAF sensor code
MAF sensor code
I just got my heads and cam on and ive been having transmission problems after the vig 2800 lockup converter went in. Do you guys think that the MAF problem could be causing the converter not to lock up? Its code P0100 which is a malfunction in the MAF and could be a shirt to ground, short to power, or an open circuit. An thoughts on this?
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
