in LT1Edit program, what folder to open??
Old Sep 22, 2003 | 04:49 AM
LT1RX7's Avatar
I am just now starting to get into the edit. On the LT1Edit program I am suppose to open a folder, what folder? Do I have to have it plugged into a PCM before I can open it or something? Sorry, I'm alittle slow with computers
Old Sep 22, 2003 | 04:54 AM
LT1RX7's Avatar
this is what the user guide says
"When starting the editor, go to the ?File? menu and select ?Open?. The editor assumes you have a *.LT1 file for your PCM. This file contains the Flash images from both PCM processors. PCMprog reads and writes the flash using this format"
So does that mean I have to plug into my PCM, have the computer read the PCM and create a folder for me to open?
Old Sep 22, 2003 | 10:02 AM
madwolf's Avatar
It doesn't matter if the file is in a folder, desktop or just the root C: drive.... but yes, you do need to connect to your PCM and read the program first, before you can make any changes.
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
NewsBot
Sep 30, 2015 04:20 PM
MDZ28
11
Sep 24, 2015 09:15 AM
marlar98
Sep 19, 2015 07:53 AM
Toxintwins
Sep 11, 2015 11:13 AM
