LT1 and ProCharger P-1SC - DataMaster data
Old May 25, 2006 | 10:18 AM
-vellu's Avatar
I logged some test data (DataMaster EE data) and wanted an opinion.
http://www.transam.fi/emc/Testi%203%202006-05-25.uni
Mods are:
- ProCharger P-1SC, 2 Core Intercooler (8 psi)
(including ProCharger inline fuel pump and FMU)
- Delteq LT1 Opti-Direct Ignition
- Arizona Speed and Marine headers
- Random Technology High-Flow Cat
- Magnaflown Cat-back
Is there something wrong or not?
I’m little bit worried about the fuel pressure. My Autometer Fuel Pressure Gauge 0-100 PSI 6163 shows only 55 psi fuel pressure at 8 psi of boost (AUTOMETER Boost Gauge 6160 Cobalt Series 30 psi). I know that fuel pressure should be like 80-90 psi at 8 psi of boost. If I understand my DataMaster log, motor is not running lean? Maybe that Fuel Pressure Gauge or electronic sender is broken?
Thanks for your opinion.
-vellu
Old May 30, 2006 | 11:09 PM
Blownbird355's Avatar
Re: LT1 and ProCharger P-1SC - DataMaster data
Your fuel pressure sounds right it will increase with a 1:1 ratio. Base fuel pressure. But if you run FMU it should be higher. What fuel pumps do you have?
Old May 31, 2006 | 01:46 AM
-vellu's Avatar
I have stock intank pump and procharger inline pump.
I have already ordered Racetronix LT1 F-body fuel pump & harness kit. I like to get rid of that FMU using bigger injectors like Delphi / Lucas 42 lb / hr. '009' Disc Injectors or Siemens / Mototron Deka 4 Flow-Matched 60 lb / hr Injectors (both from Racetronix).
...and new Mail Order tune form MADZ28 or from PCM for Less.
Old May 31, 2006 | 08:32 AM
MEAN LT1's Avatar
You need to adjust your fmu.
Old May 31, 2006 | 09:04 AM
ucnu112's Avatar
Unless something's changed since I contacted MADZ28 about tuning for my Procharger, a blower-tune was too car-specific for mail order. He suggested specifically that I get a dyno tune.
Old Jun 1, 2006 | 12:05 AM
If you plan on doing upgrades get the largest injectors you can. So you dont have to upgrade again.
Old Jun 3, 2006 | 09:56 PM
wicked_95z's Avatar
Yeah, definitely get the mototron 60's. You'll need them
D1SC383LT4
Jan 1, 2016 01:56 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
