Low RPM part throttle timing adjustments for cammed cars?
Old May 27, 2003 | 09:49 AM
RichJ's Avatar
What sort of timing changes are folks with head/cam cars making in the bottom RPM range? I'm trying to pick up the throttle response of my car in the 1400-2000 rpm range and have been experimenting with advancing the timing in the higher load ranges. It seems to be working (better power down low with no knock retard), but I'm not sure how much is too much or whether it's all in my head. Can anyone make suggestions?
Thanks.
Old May 27, 2003 | 12:46 PM
383Z4ME's Avatar
Hi Rich,
I am with you. If I can idle at 22-24 degrees I see no need to have the timing off idle be any less then that
Rick
Old Jun 3, 2003 | 07:54 PM
Highlander's Avatar
My timing at idle is at 34º
Old Jun 3, 2003 | 11:36 PM
Kris96WS6's Avatar
A very intersting read:
http://www.carprogrammer.com/Z28/PCM...k%20tuning.htm
Old Jun 4, 2003 | 11:08 AM
LT4POWR's Avatar
that's good info, thanks
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
IgorT.455/406
Jun 4, 2003 03:32 AM
