Low/High Impedance Injectors
I've been looking at DFI sites and everything I see is about low/high impedance injector controls. Whats the main difference, is it gonna be something w/ reaction timing? And also what's stock on the LT1? Thanks, Rob
Originally posted by LiT1_up
Injectors bigger than 50 lb/hr are low-impedance. The PCM will not run low impedance injectors.
Low impedance converters draw more current, and the stock PCM injectors drivers can't handle that much heat.
Rich Krause
Another thing, the LI 'peak and hold' injector has a faster open/close response time. This allows the use of larger injectors to be programed to a lower pulse ms rate. This is helpful to get a cleaner idle cuppled with the larger capacity injector.
autoxr166
Sep 25, 2015 04:21 PM
