Looking for a bin file 95-95 Pontiac F-Body
Old Apr 18, 2009 | 08:37 AM
MichiganSkip's Avatar
I need a STOCK bin/lt1 file from a Pontiac F-body with the performance shift table values. My 95 Camaro tables are the same for normal and preformance shifts and I'd like to see what the difference is on the Pontiac side.
Skip in MI
Old Apr 18, 2009 | 09:27 AM
bobdec's Avatar
You can try here " http://www.monodax.com/forums/tunercat-file-request/ " Strange, my stock '94 Z28 tables are different between normal and performance shift pints, and a big difference in the line pressure offset tables. Just for your reference I e-mailed you a copy of my old semi modified .bin (Z28 A4 w/old 273 rear settings) the performance shift tables and line offset are intact stock settings other stuff may be changed.
Old Apr 18, 2009 | 11:52 AM
My stock tables are definitely different between normal and performance modes.
Old Apr 18, 2009 | 02:46 PM
I was under the impression from discussions years ago that the Camaro's tables were the same and the Pontiac's were different because the Pontiac had the switch to enable the performance mode and the Camaro's didn't have the switch.
Thanks for the replies guys
I've had 2 95 Z28's both with 2.73's and the tables were alike.
Old Apr 18, 2009 | 03:02 PM
That info was debunked a long time ago. The only thing different was that the Camaro did not have the switch.
Perhaps it was the 2.73 cars only? Mine has 3.23s.
NewsBot
Aug 3, 2015 02:40 PM
4586
Aug 2, 2015 01:45 PM
whitehooptie
Jul 22, 2015 10:25 PM
NewsBot
Jul 8, 2015 06:47 PM
Jmj93z28
Jul 8, 2015 06:58 AM
