Looking for a bin file 95-95 Pontiac F-Body
I need a STOCK bin/lt1 file from a Pontiac F-body with the performance shift table values. My 95 Camaro tables are the same for normal and preformance shifts and I'd like to see what the difference is on the Pontiac side.
Thanks Skip in MI |
You can try here " http://www.monodax.com/forums/tunercat-file-request/ " Strange, my stock '94 Z28 tables are different between normal and performance shift pints, and a big difference in the line pressure offset tables. Just for your reference I e-mailed you a copy of my old semi modified .bin (Z28 A4 w/old 273 rear settings) the performance shift tables and line offset are intact stock settings other stuff may be changed.
My stock tables are definitely different between normal and performance modes.
I was under the impression from discussions years ago that the Camaro's tables were the same and the Pontiac's were different because the Pontiac had the switch to enable the performance mode and the Camaro's didn't have the switch.
Thanks for the replies guys:) I've had 2 95 Z28's both with 2.73's and the tables were alike. |
Originally Posted by s_willis
(Post 5929075)
Thanks for the replies guys:) I've had 2 95 Z28's both with 2.73's and the tables were alike. Perhaps it was the 2.73 cars only? Mine has 3.23s. |
