kPa?
kPa?
I know that kPa is a unit of measurement of pressure by the pcm, but what i dont understand is what the k stands for? I know that Pa(pascal) is a unit of measuement of atmoshere pressure, 1 atm=101,325 Pa, so why is 100 the max? How does the k change the unit measurement?
There is no "limit" of 100kPA.... a 1bar MAP sensor will generally output the voltage (5.0) that corresponds to over 100kPa. I've seen some scanner data logs where the barometric pressure (BAR) is reported at up to 103.7kPa. You generally do not see many readings over 100kPa for the MAP reading, since there is always "some" pressure loss through the filter, ductwork, throttle body, etc.... There's nothing magic about 100kPa, except that by definition it is "one atmosphere" in the metric system, which sets the standard atmosphere at the equivalent of 14.5psia, rather than the 14.7psia used in the English system.
I see 103.7kpa under WOT, but I'm adding a little air to the mix!
canbaufo
Mar 19, 2003 03:19 PM
