timing
Old Oct 5, 2003 | 10:29 PM
Schurters LT1's Avatar
timing
1-What would a nice timing cure look like at wot.
I no every car is diff for timing but just ie: would be nice from old files or what you like see.
2- Where should you start the timing for wot, 85kpa,90kpa,95kpa,100kpa full timing
3-ie: if you start wot timing at 85kpa say you have
4000 rpm/85kpa-39.0 timing in tuner cat do you make 90/95/100kpa timing the same or do you advance it
4- is it the higher the rpm the more timing you put in +1-2* or is it more.
my timing at 100kpa
rpm/kap-timing
400-22
600-22
800-22
1000-23
1200-24
1400-26.5
1600-27
1800-28
2000-29.5
2200-31.5
2400-32
2800-35
3200-35
3600-35
4000-35
4000extended spark adv table-36.5
4500-36.5
5000-36.5
5500-36.5
6000-36.5
6500-36.5
7000-36.5
i have 7* kr at 4000rpm up to 5500rpm this is the fixed table i pulled out 5* just to start
Old Oct 9, 2003 | 09:18 PM
CRCDUDE's Avatar
HHMMM
With our TA I pretty much brought in full advance by 4000 rpm
and at 90kpa this way when we go full throttle on the trans brake we have max power, and helps stall a bit higher
i keep total timeing in at 95 kpa because sometimes wiht the weather in the summer you wont even see 100kpa
I have disabled the knock retard and keep a close eye on the knock count ( i'm still old school) this seems to produce the best results with OUR car. We ran a best of 11.14 @119.5 a couple of times so it s not a 1 shot wonder car.
Check out threadedtire sig for car detials
Old Oct 10, 2003 | 05:10 AM
TriPinTaZ's Avatar
You may be seeing knock retard from lack of fuel. try increasing your VE tables by 10% between 90-100 KPA and then check your knock retard. If there is less KR, go to your PE tables and add more fuel in the areas you see the knock.
I currently run 41-40degrees of timing from 0-3600 RPMs then 39 degrees from 3600-4000 and 38 from 4000-6800 and 37 at 7000 RPMs with no knock retard. I also have 12.3:1 compression. I think your not giving you car enough fuel at WOT causing a lean condition casusing spark knock.
Old Oct 10, 2003 | 04:35 PM
WOW WOW Tripintaz you are runing that much timing in that low of rpm.
Yes i do have kr but i am not lean when i had kr i was 12 afr so i have pulles out 5* timing in the tables and i will see what happenes.
What is the VE table
this is my timing from 85 -100kpa
my timing at 100kpa
rpm/kap-timing
400-22
600-22
800-22
1000-23
1200-24
1400-26.5
1600-27
1800-28
2000-29.5
2200-31.5
2400-32
2800-35
3200-35
3600-35
4000-35
4500-36.5
5000-36.5
5500-36.5
6000-36.5
6500-36.5
7000-36.5
Old Oct 10, 2003 | 04:51 PM
If i have 34* in closed tps can you carry that over to the wot tables 0-3000rpm and be safe or is this some thing to do on the dyno?
Old Oct 10, 2003 | 10:02 PM
TriPinTaZ's Avatar
well I also have a 260 duration solid roller cam, thats why so much timing
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
