knock sensor ?'s
Old Sep 9, 2004 | 09:34 AM
agrsiv95's Avatar
knock sensor ?'s
Does the 95 OBD1 cpu have a default knock setting if it's unplugged/wire broke? I get 6 degrees of retard at light load and it slowly goes away if I stay at the same load no matter what I change in the timing table. I have pulled 8 degrees across the board twice with LT1 edit and still 6 degrees. Now the car is a pooch.
Thanks,
J
Old Sep 9, 2004 | 11:42 AM
Re: knock sensor ?'s
I have heard that it retards the timing a set amount of degrees if there is a DTC for the sensor circuit, but I have not verified that, myself. Have any trouble codes?
Old Sep 9, 2004 | 01:32 PM
agrsiv95's Avatar
No codes at all. I did a search and couldn't find any direct info for the problem I'm having. I do have all Comp valvetrain; Pro Magnum lifters, pushrods and 7/16 rockers, set the lash cold then hot and the car has 16 inches of vacuum at idle. It has the LT4 KM (nothing changed) and a Dynaspark . The timing was severely off with stock opti thanks to the shaft retaining screws losing thier heads. It is a new KM and I did use pipe tape to seal it and torqued it to 18ft lbs. If the signal wire was shorted to ground, it would throw a code right? The signal wire is running in the same loom as the ABS sensor and starter wires to get it away from the headers.
J
Old Sep 9, 2004 | 10:41 PM
Yeah, if the wire was shorted to ground, it should cause a DTC. If you want to check that wire, it should have 5v on it with the key on and disconnected from the sensor.
KYWes
Jun 14, 2022 06:52 AM
350350
14
Aug 11, 2015 12:03 PM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
