Knock Module Needed
Old Nov 11, 2010 | 04:37 PM
  #16
koolaid_kid's Avatar
Re: Knock Module Needed
It is real easy to do, and you are correct, it allows you to swap back and forth as you wish.
Also, the price. Resistor packs are $1.99 at Radio Shack. A bit of solder and you are done. I never figured out what to do with the extra resistors, though.
As a matter of fact, if you decide to do this I will send you a couple in the mail. Just PM your name and address. I can even send a short bit of solder if you do not have access to any.
Old Nov 11, 2010 | 05:25 PM
  #17
TT350's Avatar
I emailed ION @ Madtuner today and he is going to socket the board and put in the resistor for me.
Old Nov 24, 2010 | 09:07 AM
  #18
Stl94LT1's Avatar
Originally Posted by TT350
I may do that.
If this is done to the OBD1 PCM so you can run the OBD2 KS and switch back to OBD2
with out changing KS back that's cool.
I'm nuts and bolts kind of guy.
I would just tap the block and put the OBD1 KS next to the OBD2 and swap the plug
to swap PCM's
No need to tap the block, just use the block drain on the left side of the block. This is where the Y-body cars place the second sensor.
MadMav
May 25, 2015 09:35 PM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
mjcent922
Jul 27, 2002 12:42 PM
