Ion or any programer
Old May 29, 2004 | 04:16 PM
93transam1234's Avatar
Is there a way to program out my rear ABS sensors and have the system work with only the abs sensors connected at the front of the car?
Old May 29, 2004 | 04:45 PM
Kryckter's Avatar
Im going to take a stab at it and say no. Im pretty sure the PCM does not control the ABS. The ABS system has its own computer so therefore I dont think you will be able to program out the rear sensor.
Old May 29, 2004 | 05:06 PM
where is the computer that controls the ABS system?
Does anyone program those?
Can i switch a non-traction controled cars for a traction controled cars to make a rear out of a traction controled car work on mine that doesnt have traction control?
Old May 29, 2004 | 06:10 PM
madwolf's Avatar
Sorry, can't help you with the other stuff, but the PCM does not control the ABS. It has its own "brain" and nobody programs those. There might be a way around it though.
Old May 29, 2004 | 06:35 PM
mike 96 ws6's Avatar
wild guess here? {short of installing a carrier from a non-traction controled car with the relucter ring on it and drilling the housing to mount the sensor }
you might be able to wire your harness to one side just to get it going if you don't run into a frequency conflict {frequency of carrier mounted reluctor vs axle mounted.}
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
MDZ28
11
Sep 24, 2015 09:15 AM
marlar98
Sep 19, 2015 07:53 AM
FredM
Aug 14, 2015 01:49 PM
whitehooptie
Aug 10, 2015 07:02 AM
