hypertech programmer -> rev limiter & shift rpm
Old Oct 3, 2003 | 07:16 PM
sabre81's Avatar
are there optimal settings for these ? I heard the a4 shifts too late? also should i raise or lower the rev limiter? i dont want to kill my engine
Old Oct 4, 2003 | 12:50 PM
Hal Fisher's Avatar
the a4 does shift a bit slow and appears worse because the rpm gauge is usually a little off (+200 or so). But its able to handle the stock settings even with its oe weak springs. If you had a supercharger or something I would say go a little lower, or with better valve springs I would say higher.
Hal
HarleyZ28
Oct 5, 2015 06:23 AM
cristian1311
Apr 22, 2015 10:20 PM
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
Rbain
Sep 4, 2002 12:35 PM
