How to re-program A4 for an M6 conversion ???
Old May 3, 2003 | 12:59 PM
Z_Maniac's Avatar
I'm really thinking about swapping out to a 6 spd and while going down the list of things I will be needing I thought about the programming. Will I just be able to find an M6 file that closely resemble my setup and copy it over to my PCM file or is there a trick to it??? I've been searching for any "How-Tos" on this subject w/ no luck so I'm hoping someone that has already done this chime in.
Thanks.
Old May 3, 2003 | 01:54 PM
tjwong's Avatar
There isn't any tricks to it at all. Just go into your PCM Switch table and disable the A4 transmission diagnostics. If you like I can send you a M6 BIN that you can look at.
Old May 3, 2003 | 02:24 PM
Z_Maniac's Avatar
Can you? That'll be great if I can take a look at it. Now, once I disable it can I just copy the m6 bin to my PCM??? I'm still alittle lost at this LT1 edit thing.
thanks.
Old May 3, 2003 | 03:21 PM
tjwong's Avatar
Emai sent
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
tdigger9899
Sep 7, 2015 10:56 AM
FredM
Aug 14, 2015 01:49 PM
