how to make my 94 a obd2
Old Sep 27, 2003 | 11:16 PM
amean94ta's Avatar
do i need the comp. and dignostic port to put under dash. see my car is screwed up form stall to high for obd1 so should i have it tuned as a m6 and use the 700 r4 i have built with man. valve bodie or stay with the 4l60e and get it changed. i really want to shift manualy and hate the eletronic control so how will i put the built 700 and make it work with computer
Old Sep 30, 2003 | 09:50 PM
Z28ROC's Avatar
Have you tried to fix the high stall problem with tuning?
You can contact Madwolf, for tuning help, as well as an OBDII conversion. I believe all you have to do is send him your PCM.
Old Sep 30, 2003 | 09:54 PM
amean94ta's Avatar
can you pm me a link to his website so i can save it
Old Sep 30, 2003 | 11:33 PM
OneFlyn95z28's Avatar
BTW Ed Write now has a 100% fix
YES I am sure
Old Oct 7, 2003 | 02:20 AM
94 TA TT2S's Avatar
Hey Ellis
I regards to this post..
..I gave up on OBD-I in the pits at a race in between rounds in Canada. we swapped my car over so I could race.. I have not had any problems since then. The car actually drives better now then it ever has and the trans mission seams to be more acurate then it ever was with shifting. Only thing we lost is WOT lock-up and I think that is tied to the missing crank sensor. I am sure we will find a fix for that also http://web.camaross.com/bb/wink.gif
Tell me ...was there anything to the crank sensor and WOT lockup???? I am in the process of the obd2 swap and need to know all you had to change so I can have it all together for when everything gets here......I would greatly appreciate it
Old Oct 8, 2003 | 11:06 AM
grygst76's Avatar
I thought 94's were obd2 How do you know if it is?
Old Oct 8, 2003 | 11:37 AM
madwolf's Avatar
All factory 94s were OBDIs. All factory 95s were also OBDIs, but with an OBDII connector.
Old Oct 8, 2003 | 12:01 PM
grygst76's Avatar
only curious because my connector is an obd2 and Mine is a 94??
Old Oct 9, 2003 | 10:38 AM
How many pins on your connector?
Old Oct 9, 2003 | 10:55 AM
grygst76's Avatar
give me a minute and I'll check
Old Oct 9, 2003 | 11:59 AM
grygst76's Avatar
this is the pin layout
I have 2 to the far right top corner and one on each side of the bottom
Victor Lamb
Aug 26, 2017 02:52 PM
HectorM52
Jul 30, 2017 11:46 AM
siguy
Nov 27, 2014 10:07 AM
