How important is it to program PCM after gear swap?
Old Aug 25, 2002 | 11:55 AM
Ryan's Rod's Avatar
Post How important is it to program PCM after gear swap?
I have an LT1 in my K5 and just finished swapping it in but my combo of 33 inch tires and 3:08 gear ratio = my truck going no where and almost stalling every stop light. I'm swapping in a 4:10 or 4:56 ratio but how important is it to program my PCM after I do this swap?
Old Aug 25, 2002 | 03:09 PM
gb95zconv's Avatar
Post
The biggest thing is that your speedometer is going to be off if you dont reprogram it. For a manual I dont think anything else is effected. There may be other issues with an automatic such as shift points.
Greg
95 Z28 conv M6
Georgia F-Body Association
Stage 1 heads, 1.6rr, Meziere WP
lt4 hot cam,lt4 timing chain kit,52mm TB,
Hooker Headers, Pro 5 shifter,3.73s,
NX 150 progressive,
Self-tuned via Tunercat
Old Aug 25, 2002 | 05:39 PM
Ryan's Rod's Avatar
Post
Yeah, that's my issue, is my transmission 4L60E going to be alright if I change the ratio in the rear end?
Old Aug 25, 2002 | 05:45 PM
96z's Avatar
96z
Post
Your A4 WOT shift points will be off. If Im not mistaken the car will shift sooner than youd like it too.
96 black Z28 A4
GTP heads, GTP cam, bolt ons...
Mattucci Motorsports WNYFA FLFB
So far...12.7@108...need more practice...
The Z
DirtyDaveW
Dec 1, 2016 05:37 PM
jayvar
Feb 2, 2015 10:00 PM
Ricardo
Nov 29, 2014 10:58 AM
Jul 4, 2005 05:00 PM
