how to change from a at to mt with tuning
Old Jan 3, 2011 | 11:54 PM
DTRJAR's Avatar
Question how to change from a at to mt with tuning
what do i have to change to get the computer to a mt i will have the tunercat program thank you
Old Jan 5, 2011 | 04:28 PM
bobdec's Avatar
Re: how to change from a at to mt with tuning
If I was doing it I would get a M6 (stock .bin) code load . The M6 and A6 code loads are different, some people have posted they manually to altered the A4 by changing tables and constants. If you are stock then a code load is easier. Just verify rear gearing of the M6 load as it may be different than your A4 rear.
Old Jan 5, 2011 | 04:44 PM
DTRJAR's Avatar
where can i get it from thanks
Old Jan 7, 2011 | 05:38 PM
bobdec's Avatar
You can post here http://www.monodax.com/forums/tunercat-file-request/ or look here http://www.monodax.com/forums/tunercat-files/ . I have a '94 stock M6 .bin , it's s/b the same as the '95 if you want it PM me with an email address to send it to.
Old Jan 8, 2011 | 10:52 PM
DTRJAR's Avatar
thanks for the help i got one now
Old Jan 9, 2011 | 10:07 PM
MikeGyver's Avatar
I think all you need to do it uncheck the Automatic Trans option. this disables the auto trans tables, and also rescale the VSS. auto uses 40 pulses per rev, manual is 17
DirtyDaveW
Dec 1, 2016 05:37 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
grgguy
17
Feb 23, 2015 07:57 PM
InfernalVortex
Jan 17, 2015 09:35 AM
