help with datalog questions
Old Sep 1, 2005 | 02:39 PM
Z95m6's Avatar
Well this is the first datalog i've done on my car after the BRE cam. For the most part i don't see any problems my air flow is up over 35 gps over my old 230/236 which is good, but the RPMs are what is funny. If you look at the graph the rpms kind of jump up in steps, you can even see the rpms climb and fall just slightly. Does anyone have any idea what could be causing this? You don't feel it in the car. Here is the log.
http://www-personal.ksu.edu/~bperkins/BREcam.uni
http://www-personal.ksu.edu/~bperkins/BRE.zip
Oh i still don't know whats causing the Data errors every once in a while.
Old Sep 1, 2005 | 03:26 PM
2QUIK6's Avatar
Re: help with datalog questions
I don't have the software on this machine to view the log, but are the rpms stepping up with IAC count movements? If so, maybe the PCM is trying to get to the target idle speed as a different cam may idle differently. Maybe the IAC needs resetting or adjust for the correct idle speed.
Old Sep 1, 2005 | 03:37 PM
Z95m6's Avatar
Its not a problem at idle, its at WOT.
Old Sep 6, 2005 | 01:36 PM
madwolf's Avatar
From looking at your log, you are running lean and your engine is struggling from it. The car misses, but you probably don't feel it. Is your knock retard disabled? I also think you are running a bit too much timing.
Old Sep 6, 2005 | 02:07 PM
Z95m6's Avatar
No i have the KR enabled. At least i'm 99% sure its enabled. I'm actually running the same tune my buddy has on his 224/230 but i'm sure he has the KR turned on. I'm running a custom cam and the specs aren't even really that close to what he has. The duration is close but thats about it. I'm not sure if you can really tune for other stuff, like LSA and ICL. Ion how much do you charge to just make a tune that you can send to me? Do you think there would be a lot that you could improve upon?
Edit: thanks for taking the time to look at this Ion.
Old Sep 6, 2005 | 02:10 PM
madwolf's Avatar
Go ahead and fill out a tuning order sheet here:
http://www.madz28.com/order.php
and I'll email you a tune when I have some time, then you can do a datalog and if we see some improvements, you can get the unlimited email package for $60. Otherwise it'll be a bit cheaper for 1 tune.
Old Sep 6, 2005 | 02:25 PM
Z95m6's Avatar
Done, thanks Ion.
Old Sep 6, 2005 | 02:31 PM
madwolf's Avatar
I forgot to mention... email me your current bin when you get a chance. It will be easier to get the tune closer having the bin you used on the logs to compare to the logs.
Thanks.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
