General Questions - FAST XFI
Old Jul 12, 2008 | 09:51 AM
Fire67's Avatar
-A stock style VSS... Is the signal "Discrete" or "Inductive"? Got it on another forum... Inductive for those that may wonder
-Are any of you FAST users using a knock sensor? If so how well does it work with non-stock displacement, roller rockers, and longtube headers? Furthermore, is it even worth while if running 100 octane unleaded and a small wiff of methanol to cool things down?
-Since, I'm using only one WB meter... Does anyone have a preference as to whether the sensor should be mounted in the Y-pipe after the merge (to get an average of the entire motors A/F ratio), or in a header collector (getting an average from only one side of the motor?
Will probably have more questions once I get to start this thing up again.
Thanks in advance.
Old Jul 12, 2008 | 10:29 AM
Fire67's Avatar
One more I just thought of... The FAST XFI basically only gets a crank signal from the opti-spark. Anyone know if its possible to use one of MSD's cam sync pickups that clamp onto the #1 spark plug wire? Just saw it in one of their catalogs for the first time. And it appears to be of the same type that dyno's use.
Old Jul 14, 2008 | 05:11 PM
Fire67's Avatar
Ttt...
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Mar 1, 2015 01:33 PM
maybe2fast
Feb 5, 2015 05:14 AM
ChrisFrez
Jan 18, 2015 08:05 AM
guionM
14
Jun 19, 2002 08:30 AM
