gen VII DFI
Old Sep 17, 2007 | 10:12 AM
brand-x's Avatar
gen VII DFI
I have a leann spot in my VE table between 4-5k rpm that I cant adjust out. It runs about 12:1 through 4k then 17:1 till 5k (breaking up bad) and back to 12:1 till shift. I've raised the value in the ve table so much and still nothing. that Are there any other table that I need to be looking at? Also, if unburnt fuel is read as a lean condition....could it be too rich in the VE table? That just doesnt sound right, does it?
Old Sep 17, 2007 | 02:38 PM
bkrepindy's Avatar
Are you using a wideband? If so are you allowing closed loop correction at WOT? If so i'd first check your positive and negative O2 sensor feedback limits. Maybe some of the cells between 4-5K are messed up. Also, and I'm sure this is a long shot, but are you using the PE function? If it is enabled and you don't realize it the AF table could be incorrect as well.
Old Sep 18, 2007 | 04:15 PM
brand-x's Avatar
PE function? not sure if i know what that is.
Old Sep 19, 2007 | 01:26 PM
bkrepindy's Avatar
Bring up your main screen, select "configuration" go down to "fuel" (you can also hit Ctrl-U). PE is Power Enrichment Mode I believe it is available only if you have Gen 7 DFI version 4.0 or higher. From there you can set up an alternate A/F table and a threshold based on throttle position and RPM. If by chance this is enabled the A/F ratio in the table could be set incorrectly. Like I mentioned this is a long shot but the potential is there.
Thanks!
David Dempsey
Mar 12, 2016 12:42 AM
HAWG
Sep 25, 2015 11:41 AM
Z Power
Sep 19, 2015 11:19 PM
