Fuel map,Timing table.....
Old Jul 12, 2003 | 10:11 AM
streetbad's Avatar
spark map
Tuner guy is coming over. He asked me to get a timing table. Please help. I am putting in 30 lb svo's. Cam is xe218/230@112. Heads are 260/197. Long tube headers,stock short block. .026 head gasket, 93 octane fuel,M6. Is stock fuel pressure 43 or 43.5? Is ford 39 or 39.5? Thank you. Tim
Old Jul 15, 2003 | 09:04 PM
Highlander's Avatar
What exactly do you want?
Old Jul 16, 2003 | 09:02 PM
streetbad's Avatar
spark map or spark calibration
Old Jul 16, 2003 | 10:13 PM
Highlander's Avatar
Well... you have to make some runs and up until you get ping and then drop 1º and you will be ok...
Old Jul 16, 2003 | 11:01 PM
Dan K's Avatar
With your combo, the stock map will work fine to start. You'll need to tweak the wot timing though.
As far as part throttle you could probably add a degree or 2 here and there. It's just something you're going to have to experiment with.
Old Jul 17, 2003 | 08:36 AM
Highlander's Avatar
My point... after you get to the verge of pinging drop back a degree or 2 because just before pinging its too much timing and many times it doesn't like it...
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
