First run on open loop 13.3@98, 9 degrees retard!
Old Aug 23, 2002 | 06:46 AM
Fred94LT1's Avatar
Thumbs down First run on open loop 13.3@98, 9 degrees retard!
I have got to figure out why I'm getting 9 degrees of retard all the way down the track. I do have an exhaust leak, but would that cause 2-3 degrees retard at idle and if cruising at 65 mph and I put it half way to the floor I see as much as 11 degrees of retard. If I'm cruising at any speed and I let off the gas the retard will go 0.0.
I'm really at a loss here. The exhaust leak is on the SLP y-pipe. Its as if I'm running on 7 cylinders. I don't see the car hitching like a bad wire. Its just retarding so bad the car just won't get out of its own way at WOT. Anyone got ideas for me to check or look at.
Fred
1994 Z28, A4,
BEST 1/4 12.413@109.55
BEST 1/4 MPH 110.49
BEST 60' 1.668
BEST 1/8 7.884@86.35
BEST 1/8 mph 86.77
Race Weight 3600lbs
No new times with P&P heads Flow 239.4 INT 182.1 @525 lift, or
24lb SVO inj's...
Old Aug 25, 2002 | 10:43 PM
T/A lt1's Avatar
Post
I know you may consider this a bandaid but I would put a reisitor in place of a knock sensor and see what that does. Just my .02 Later Clint
1995 T/A RamAir,17x9 WS6 polished rims,A4 fresh, 3:23's,LT4 Hotcam kit, Ported heads and intake, built 355 with forged pistons, LT4KM,NX N20 kit 125-175hp, Custom programming, AS&M headers, Vigilante 2800,
flowmaster catback, Fernco intake bellow,CSI w/p,MSD 6al. New Et 12.50@107 N/A no nitrous times yet.
Old Aug 26, 2002 | 12:15 AM
Hal Fisher's Avatar
Post
Spray some carb cleaner on the exhaust leak to see if the knock goes away (on a fairly cold engine but out of open loop of course). If its not that then it could be just a bad knock sensor.
Hal
DirtyDaveW
Dec 1, 2016 05:37 PM
192cobra
Jan 26, 2015 12:12 PM
nophix
Nov 30, 2014 10:26 PM
Kyle@CSS
Jul 23, 2002 10:40 AM
