Firmer shifts programmed(PCM)??
Old Jul 23, 2004 | 09:02 AM
  #16
gamecockfan04's Avatar
Re: Firmer shifts programmed(PCM)??
WoooHooo, My cable finally came in so Im going to get some files tommorow. For everyone that wanted to know where my shift points are your going to have to tell me how I can record this info through Freescan, because this will be my first time using it.
Old Jul 23, 2004 | 10:13 AM
  #17
DarkHorse's Avatar
Actually, you'll record your PCM through TunerCat and that will show the tables.
Old Jul 23, 2004 | 07:14 PM
  #18
dmoss69's Avatar
yeah, read the file with winflash or dos tunercat, save it, then look at it in the tunercat program.
If you need help, let me know. You may swing by my shop and I'll help you.
I'm on your way to O'burg dragstrip.
D Moss
Old Jul 23, 2004 | 10:21 PM
  #19
LWillmann's Avatar
My understanding is that the transmission can only run up to 90 psi without being upgraded.
I've seen people adjust the line pressure vs TPS and I've seen people adjust the pressure offsets.
Old Jul 23, 2004 | 11:17 PM
  #20
dmoss69's Avatar
we adjusted shift time values on my friends camaro, and let me tell you, it shifts as hard and fast as my transgo kit in my pickup.
D Moss
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
97SSdude
Dec 31, 2014 07:43 PM
Jul 4, 2005 05:00 PM
