Firmer shifts programmed(PCM)??
Re: Firmer shifts programmed(PCM)??
WoooHooo, My cable finally came in so Im going to get some files tommorow. For everyone that wanted to know where my shift points are your going to have to tell me how I can record this info through Freescan, because this will be my first time using it.
yeah, read the file with winflash or dos tunercat, save it, then look at it in the tunercat program.
If you need help, let me know. You may swing by my shop and I'll help you.
I'm on your way to O'burg dragstrip.
D Moss
D Moss
My understanding is that the transmission can only run up to 90 psi without being upgraded.
I've seen people adjust the line pressure vs TPS and I've seen people adjust the pressure offsets.
carguyshu
Jan 22, 2017 11:19 AM
Jul 4, 2005 05:00 PM
