failed Md emissions - need help
Old Jun 6, 2007 | 09:12 PM
95wannabe's Avatar
I have a totally stock 94LT1 swapped into a 95 base camaro body. Motor has about 100,000 miles and passed Maryland emissions 2yrs ago. This time, I failed HC. I logged a couple minutes w/Datamaster and wondered if someone could look at it for me ? I have no idea what its telling me, but am willing/eager to learn. I have Tunercats, but only used it to put the file in the PCM when I did the motor swap originally. Could I email this to someone to look at ?
Old Jun 8, 2007 | 09:21 PM
95wannabe's Avatar
should I post this in "LT1 Engine Tech" ?
Old Jun 9, 2007 | 12:13 PM
What were the exact test results, and the pass/fail limits for HC, CO and NOx?
Old Jun 9, 2007 | 01:12 PM
95wannabe's Avatar
HC limit 0.900 GPM result 1.629 GPM
CO " 20.0 " 9.2169
NOx " 2.1 " 2.0959
As you can see, failed HC, and almost NOx. I have not touched this motor since I put it in w/80,000 on it. At that time, I put new plugs & wires on and a new cat and Hooker cat-back. I've had no issues with it. What do ya think ?
Thanks for the reply
Old Jun 9, 2007 | 10:36 PM
With both HC and NOx being high, I'd suspect the cat.
Old Jun 10, 2007 | 03:50 PM
95wannabe's Avatar
hmmm...ok, any way to get a better feel that its pointing to the cat ?
Old Jun 20, 2007 | 03:23 PM
1987IROC350's Avatar
HC usually means you can change your oil and filter and plugs to pass in the retest. My emission guy used to make me run up and down the highway a few minutes and come right back for my retest. It always passed after I ran it hard.
When you go to get an emission test make sure your car has been running a minimum of 30 minutes. It takes almost that long for your cat conv to work properly. So if there is a couple people in front of you leave your car running. You stand a much higher chance of passing.
So did you pass now?
Old Jun 20, 2007 | 06:51 PM
95wannabe's Avatar
good call ... put on a new one and passed !
Thanks for your help.
Jeff1904
Jun 5, 2016 05:00 PM
damnyankee36
Sep 9, 2015 07:06 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
Boss002
Jul 24, 2015 10:47 AM
