F-body 93 PCM vs 94-97 PCM
Old 02-26-2003, 08:54 PM
mastrdrver's Avatar
Does the 93 PCM still have the 7000 rpm fuel table limit that the 94-97 PCM have?
Jeremy
mastrdrver is offline
Old 02-26-2003, 09:54 PM
wrencher's Avatar
The 93 ecm is port fuel (bank fired injection) .Otherwords fires 4 injectors at a time & only has 2 injector drivers.All aplication specs are on removable prom chip. The 94-97 pcm is a seqential fuel injection control unit. It fires injectors 1 at time as intake valve opens & has 8 injector drivers. All aplication specs are on a electronicaly erasable prom. The seqential pcm is much better & they are not interchangeable.
wrencher is offline
Old 02-26-2003, 10:30 PM
Dr.Mudge's Avatar
Unfortunately that doesn't answer his question. I dont happen to know, but I dont doubt that you have the same limit "we" do. Otherwise, those not wanting to spend DFI/FAST/MoTeC money for beyond 7k would probably be converting to SD 93 setups.
Dr.Mudge is offline
Old 02-28-2003, 01:49 AM
Soma07's Avatar
Re: F-body 93 PCM vs 94-97 PCM
I think so, the VE table ends at 7k but oddly both the PE and spark tables go up to 7500rpm (according to Tunercat)
Soma07 is offline
Old 03-03-2003, 06:20 PM
KCFormula's Avatar
Jason- would tunercat be worth purchasing for us '93 guys? currently I run the TTSDatamaster, what would tunercat have that datamaster doesnt?
KCFormula is offline
Old 03-03-2003, 07:09 PM
turbo_Z's Avatar
tunercat is strictly a tuner....datamaster is strictly a scanner.
turbo_Z is offline
Old 03-03-2003, 11:13 PM
Dr.Mudge's Avatar
Uhh, exactly.
Dr.Mudge is offline
Nayr
03-03-2023 08:34 PM
G-BODYT56
01-14-2022 11:14 PM
n2oblkz
10-12-2015 01:53 AM
fift5
11
10-01-2015 10:31 AM
drt
09-27-2015 04:39 PM
Quick Reply: F-body 93 PCM vs 94-97 PCM
