ECM are they the same
94-97 are similar. The main difference is the OBD-I (94/95) vs. OBD-II (96/97) configuration, and they are not interchangeble. Starting in 1998 with the LS1 engines, the PCM is completely different, using a much more powerful, faster operating system, and significant differences in, for example the ignition system and the source of the crank and cam position data. There is no way (short of some major surgery) to put a 98+ PCM into a 94-97 with an LT1 engine.
