dyno tune or have garage scan car?
Re: dyno tune or have garage scan car?
Originally Posted by flusz28
the car is in park and its just idling. o2 were off the wall like 400 something so also had to change them out,very black also.. fuel intergrators are at 128 also... open loop is what the car is at i guess you would say when its at idle.
Sorry I'm not much help. I'd post in the forced indution blower section to ask about the FMU? Have you pulled your valve covers to see if anything is broken. You could also take a spray bottle with water and spray it on each header to see if you have any cold cylinders. Have you visually seen the spray pattern of your injectors? maybee one or a couple are stuck open constantly spraying?
ZMAN
ZMAN
the injector idea could be a issue.. dude this car ran like a monster with minor boltons. when i got the computer tuned and blower put on the car it has ran like crap ever since then..... bout to just burn it. sick of screwing with it..
pull the injectors up out of the intake. Disconnect the coil so it won't start. Have someone turn the key over and you can see all the injectors spray. They should all look like a fine mist in a conical pattern. Use rags to clean up the mess which won't be that bad.
ZMAN
ZMAN
J/K
Did you do the install? have you gone back to the basics looking for anything disconnected, vacume leak, does it backfire? Could you get a vid of it running it may give us a better idea of what the problem is. Also, do you know anybody with a laptop and a ALDL connector that could run datamaster for you? Just trying to give you more ideas.
thanks for the ideas guys
nope i don;t have any friends thats have f-bodies. they don't have sports cars anymore... they don't have laptops either. i can't win-haha. well acouple weeks ago it was backfireing i pulled all the wires off cause i figured that was the issue. haven;t messed with the car since then.. well that same day i did rstart the car and it backfired on me when i reved it up to try and clean the idle up. yeah i didn't leave anything unplugged or disconnected i checked all that twice.. thing is with no serivce engine lights on i can't figure what it could be that would make the car run like crap,other then it dumping to much fuel-since plugs and o2's were getting fouled up.. i hope saturday when i take it to the dyno this guy isn't lik. pissed cause i wasted his time cause my car isn't running great. i wish i had a way for you guys to hear it running...
If it is running that poorly, backfiring and such, why would you be taking it to a dyno? (unless this person is going to diagnose and fix your car, too) Sounds like you might have a spark delivery problem.
i dunno, i guess i figured the richness was the whole issue. opti is brand new-delteq system is brand new,plugs and wires are brand new. nothing is mixed up wire wise or coil wise. this is the first car i have ever worked on before as in building up the motor.
well i fired the car up on tyhe first tuen and it ran fine. i had it running for acouple mins while i was pumping up the brakes. shut it off and then tried to restart it and it would just crank and not turn over??
PM Bersaglieri (Dustin) I think he may have a laptop with scan functions. Otherwise you need to drive to Akron and I can scan it for you. Either way - talk to Dustin, he comes up to the house often and can help.
Hey darkhorse- i sent him a email instead.. should i have pmed him instead? if i could trust it would ran well enough i would bring it up to you. i wanted to get it dyno tuned in Stow at a place my buddies friend owns saturday. but i start the car up it starts fine and runs fine. i shut it off and it doesn't want to start back up?
