DTC 33 Problem
Old Jun 12, 2010 | 12:27 AM
Meen95z's Avatar
Unhappy DTC 33 Problem
On my 95' Trans Am I get a code 33 at idle in gear, if its in park or neutral or moving it goes away. On my scanmaster the map reads 19 while driving steady or in park/neutral. It reads 25-26 while at a idle in gear. I have a aggressive cam and such. It didnt do this until I turned the 02's back on and put a different nitrous plate on. I see no vac leaks either. Any ideas?
Old Jun 12, 2010 | 11:28 AM
Is the ScanMaster reading the MAP in "Hg? What is the idle in neutral RPM? What is the idle in drive RPM?
Old Jun 12, 2010 | 12:35 PM
Meen95z's Avatar
yea i think so on the hg. My idle in gear is 1000 rpm and idle in neutral is 1200rpm. Should I open the tb blades more?
timmy39120
May 8, 2015 11:41 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
maybe2fast
Mar 16, 2015 11:59 AM
David Dorris
Jan 17, 2015 08:10 PM
dreamer1q
Aug 20, 2002 11:19 AM
