disabling vats didn't work, how do i do it.
Old May 22, 2005 | 09:34 PM
SSRZ28's Avatar
ok, i just installed a remote start on my 95z. it will only work if the key is inserted into the ignition hole. so obvisously its my vats. i used lt1edit and under the function enable drop down menu, i went to "vehicle anti-theft = 4" and turn that from "on" to "off"
but this still didn't work. Vats is still active. is there something else im suppose to do in the pcm?
Old May 23, 2005 | 09:11 PM
jchevy's Avatar
Re: disabling vats didn't work, how do i do it.
There starter kill function is still enabled, the fuel cut off is what you disabled in the PCM. Shoebox's site has a write up on how to wire in a resistor for the VATs to disable it.
Gtpguy
Jan 26, 2015 04:50 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
fpete1992
Dec 11, 2014 03:51 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
