DFI or lt1 edit
Old Oct 21, 2002 | 09:45 AM
lt4 fd's Avatar
DFI or lt1 edit
Doesnt lt1 edit allow you to do the exact same thing as Accel DFI? If not what is the differnce?
Old Oct 21, 2002 | 12:35 PM
One major difference.... the aftermarket computers offer the advantage of being able to handle "power adder" setups more easilly..... a second program triggered by an N2O arming switch.... or a boost sensitive system using a 2-bar or 3-bar MAP sensor for S/C applications. Can't do that with the stocker. For an N/A application, you can achieve a lot with the stock PCM. The aftermarket applications generally provide a wider array for fuel and timing maps, better injector drivers (allowing low impedance injectors, but there is a "patch" for the stock PCM), programming beyond 7,000rpm, additional inputs and outputs for other functions. The aftermarket systems can also be adapted for 8-coil direct fire ignitions..... e.g FAST/eDIST, MoTeC/IEX.
Old Oct 21, 2002 | 01:02 PM
97 RedSS's Avatar
Sry to butt in but did you get my email Fred?
My email has been acting up a lil so I dont know if it sent..
Cody
Old Oct 21, 2002 | 03:41 PM
lt4 fd's Avatar
well i am planning on a turbo setup so is it an absolute must have or is it possible to get the stock one to read over 1 bar because I cant afford it at the moment and I'll have to put off my buildup again , but if theres no other way, then theres no other way I guess. Thanks for the help.
Old Oct 21, 2002 | 05:10 PM
97TA-WS6-Con's Avatar
I cannot address this with respect to turbo's but I would strongly suggest you get an after market computer. I tried to use LT1 edit and though there are MANY guys out there succesfully using Edit on a blown car, I found it a hard slog and had to rely on other people a lot.
I'm assurred that the FAST is a lot more user friendly. I wish I had gone with it from the start.
Old Oct 21, 2002 | 07:50 PM
lt4 fd's Avatar
I took a look at thier website but didnt see any prices....what did you pay for yours and what all does it come with and what all do I need that it doesnt come with? Thanks.
Old Oct 21, 2002 | 11:34 PM
Cody
Yes, I received it. I have away a lot recently, and have a lot of logs to look through.... might take a while for me to get to it.
Fred
DirtyDaveW
Dec 1, 2016 05:37 PM
oldschool
Feb 9, 2016 09:21 PM
big worm
Feb 13, 2003 01:45 PM
Bando
Aug 2, 2002 02:18 PM
