datamaster problems, wont read PCM
Old Dec 21, 2003 | 11:40 PM
Robert95z's Avatar
Im trying to remember exactly what it said, but when i do "Test Comm" it will say "PCM detected" blah blah right... but when i try to start a recording session it says it cant read the PCM... I should have probably wrote it down, but has any1 had this problem?
-Robert
Old Dec 22, 2003 | 05:03 PM
94ZRagtop's Avatar
I've never trusted the Test Comm button in Datamaster.
If you have trouble connecting, it's either a laptop issue (see http://www.akmcables.com/serial.doc ), or it could be a timing issue with the ALDL. On the Serial Communications window (in Datamaster), under one of the options, you can tweak the ALDL link timing (I never can remember exactly how to get there).
If you're using a USB adapter, select the "Disable CCM Handshake" checkmark as well, and also the USB Interface in Use checkmark (also on the SErial Comm window).
Hope that helps,
Andrew
Old Dec 25, 2003 | 12:44 PM
Robert95z's Avatar
Hope that helps,
Andrew
Still cant get this to work. I dont see the "USB Interface in Use" selection but I do see the handshake. I looked at my com ports and it shows com4 has the belkin drivers installed but when I go to datamaster com4 doesnt get any reading at all, but com3 gets ALDL but no PCM..
errr
-Robert
Old Dec 27, 2003 | 04:57 PM
Rufus's Avatar
Changing the ALDL timing is only needed for the Syclone/Typhoon version of datamaster, and should not be necessary for the LT1.
If you are using a USB interface, that is probably the issue. Very few USB interfaces support the baud rate needed for the GM ALDL communication except the Belkin #F5U103 .
If you download the 'beta' version of datamaster form the TTS website beta downloads page, it is easier to make it work with the USB interfaces - there is a selection for "USB Interface in use"
Gary
Old Dec 31, 2003 | 02:12 AM
Robert95z's Avatar
Finally got this to work, and found out im getting 6.9 deg of knock
-Robert
DirtyDaveW
Dec 1, 2016 05:37 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Jazsun
Dec 29, 2014 12:14 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
