DA2 Tuner Cat help
Old Jan 11, 2009 | 09:45 PM
RACEON's Avatar
DA2 Tuner Cat help
I am reading a Tuner Cat file for a 1993 Y Body, ECM_DA2. I am trying to find the minimum injector pulse width table. ANy idea? The only one close on my tables is "Injector PulseWidth Correction vs Battery Voltage"
These tables are as follows
VDC / usec added
.0 977
1.6 610
3.2 610
4.8 7782
6.4 7782
8.0 7782
9.6 7782
11.2 6836
12.8 4486
I am looking to lower my minimum injector pulse width for idle characteristics.
Currently my idle is around 2.0-2.3 MS at 925 rpm in my 396 LT1
Old Jan 13, 2009 | 09:16 AM
bobdec's Avatar
RACEON, I have a '94 "EE" definition file it's different from yours, but maybe close enough to help.. The Minimum Injector Pulse Width' setting for the EE definition file is in the Constants settings about 17 rows down, not in a table. If this doesn't help possibly try the http://www.monodax.com/forums/tunerc...ware-software/ forum ? or the http://www.speeddensity.org/forumdisplay.php?f=25 forum for '93 LT1's.
Old Jan 13, 2009 | 09:21 PM
sbs's Avatar
sbs
I don't see anything like that:
http://tunercat.com/pdfs/ecm_$da2.pdf
Old Jan 14, 2009 | 12:04 AM
RACEON's Avatar
I think the only thing I can do is change VE tables around idle, to lower the injector pw by changing the fuel requirements.
Old Jan 14, 2009 | 09:35 PM
RACEON's Avatar
Okay, UPDATE
Tuner Cat sent the new definition update for my year. Apparently the 93 DA2 is already set to a minimum pulse width of zero anyways.
GREEN3112
Feb 10, 2019 09:19 PM
n2oblkz
Oct 12, 2015 01:53 AM
fift5
11
Oct 1, 2015 10:31 AM
Ks0209
Oct 1, 2015 07:32 AM
Sep 11, 2015 09:44 AM
