crank trigger ignition ???
Old Apr 12, 2003 | 01:45 AM
bowtiepwr's Avatar
Question crank trigger ignition ???
>for those that plan or did the Opti replace with crank trigger type ignition ...
Are there any problems with :
getting it wet ?
the cold ?
heat ?
anything ?
Old Apr 13, 2003 | 12:12 AM
kevin97z28's Avatar
There shouldn't be any kind of problems using the crank trigger.
Probably the biggest mistake people often make is buying a cheap crank trigger kit (magnets fall out, warped wheel, etc.) In my opinion MSD makes the best trigger on the market. The crank trigger is FAST's most popular setup and it works great! I don't know which trigger or which setup your looking at, but you will not have any problems such as you would with the Opti-crap.
Kevin Carnell
FAST Engineering Team
kcarnell@compcams.com
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
chevyalltheway
May 24, 2015 04:26 PM
TT350
Mar 31, 2015 07:44 PM
