crank trigger ignition ???
>for those that plan or did the Opti replace with crank trigger type ignition ...
Are there any problems with :
getting it wet ?
the cold ?
heat ?
anything ?
getting it wet ?
the cold ?
heat ?
anything ?
There shouldn't be any kind of problems using the crank trigger.
Probably the biggest mistake people often make is buying a cheap crank trigger kit (magnets fall out, warped wheel, etc.) In my opinion MSD makes the best trigger on the market. The crank trigger is FAST's most popular setup and it works great! I don't know which trigger or which setup your looking at, but you will not have any problems such as you would with the Opti-crap.
Kevin Carnell
FAST Engineering Team
kcarnell@compcams.com
Kevin Carnell
