Convert LT1 to wideband o2?
Re: Convert LT1 to wideband o2?
The Innovate Motorsports LM-1 wideband O2 meter has an output for a "simulated" stock narrow-band O2 sensor equivalent. No reason it wouldn't work as a replacement for the stock narrow-band sensor. Might get a little pricey using a pair of the LM-1's ($350 each), and the life span of a wide-band sensor is typically much less than an OEM narrow-band.
Look at section 11.1 of the LM-1 manual:
http://www.innovatemotorsports.com/s...Manual_3.0.pdf
I'm trying to stay away from the wideband modules due to lack of money. I have never heard of anyone converting to wideband, but just wandering if anyone else has.
As for WB sensors not lasting as long as oem NB sensors, may be a issue of WBs being exposed to more abuse. Such as, different fuels, richer mixtures than oem tunes would allow, more heat exposure, and less than desireable choices of location. The LM-1 Fred was referring to above utilizes an oem volkswagon WB sensor as it's choice. Does a volkwagon oem sensor last for a lesser length of time? When used within parameters of oem tune, I would doubt it.
My understanding is that the LM-1 output replicates the lambda vs mVolt output of a stock narrow-band sensor. Hence, you simply connect the stock harness to the LM-1 "narrow-band" replicator output, and the stock PCM is "happy".... no codes/SES.
The OEM narrow-band sensor life it dictated by EPA requirements. They must last 50K miles, or more. A wide-band sensor is not subjected to those same limitations, and I suspect that the designers may choose to sacrifice some longevity for increased accuracy. Can't say that with absolute certainty though.
http://www.innovatemotorsports.com/f...ght=light+bulb
http://www.innovatemotorsports.com/f...read.php?t=232
smacz28
Aug 6, 2002 01:51 PM
don't they use the standard Bosch o2?
