Computer won't connect to PCM
Old Sep 23, 2005 | 11:54 AM
crazyfastbird93's Avatar
Ive tried datamaster and the freescan software, both do the same. I tried the aldl test program and it says it passes the fast test, but fails the longer test when the baud goes to 57600. I have a moates cable and have contacted the tech support and they want me to hook some other kind of scan tool to it, like a snap on, not sure if that works on a 93. Im able to pull codes with the paper clip method. I think the cable is no good, but any input would be appreciated.
Thanks,
Nick
Old Sep 23, 2005 | 12:50 PM
turbo_Z's Avatar
Re: Computer won't connect to PCM
Its probably your computer.. not the ECM. What can you tell me about the laptop you are using?
Old Sep 23, 2005 | 04:50 PM
Computer is basically brand new. Compaq laptop, windows xp home I think,
Old Sep 27, 2005 | 11:21 PM
infinitebird's Avatar
Are you sure you installed the drivers correctly?
I have the moates cable and it works perfectly.
Old Sep 28, 2005 | 10:54 AM
Dave '97 Z28 M6's Avatar
Originally Posted by crazyfastbird93
...but fails the longer test when the baud goes to 57600.
I'm no expert, but should the baud rate go that high????? I thought these PCMs would only run 8192????
DirtyDaveW
Dec 1, 2016 05:37 PM
Jan 5, 2015 07:14 PM
Jul 4, 2005 05:00 PM
Ryabut98
Sep 3, 2002 11:45 PM
Doug Harden
9
Jul 21, 2002 05:52 AM
