computer swap
computer swap
i swapped a computer from my 94 a4 into my frinds 94 m6, will t here be any issues besides skip shift?
he had problems getting it into gear, with his short throw, put the stock shifter back in and cant get it to go into 5th or 6th....sometimes....
You need to have the computer flashed with a M6 program. If you don't have the cable and program to do it you can take his car to a dealer and they can do it.
The A4 program is probably activating the reverse lockout or skipshift solenoids at the wrong times causing the shifting problems. The A4 and M6 programs use some of the same pin outs but for different things.
The speedo will be way off. The M6 puts out 17 pulses/rev, the A4 puts our 40 pulses/rev. The speedo in the car that has an M6 tranny with an A4 PCM will read 25 MPH at a true 60 MPH. You will also have numerous codes for the missing A4 components.... look at Shoebox's code list.
http://shbox.com/1/Dtcs.htm
The M6 will not get the "skip shift" signal, which is no problem at all. It will also not get the reverse lockout signal, meaning he will have to strongarm the shift lever hard to get it into reverse.
The idle speed will also be screwed up, since the A4 is programmed to idle at 550 RPM in gear, and the M6 is programmed to idle at 800 RPM.
Since both PCM's appear to be from 94's, the knock sensor is a non-issue.
The b13 pin out is for the 3-2 solenoid in the auto program and is for the skip shift solenoid in the m6 program. He said he was having shifting problems so it seems logical that the skip shift solenoid being activated at the wrong time by the auto program could cause shifting problems.
In any case the solution is to have a m6 program flashed into the a4 computer.
carguyshu
Jan 22, 2017 11:19 AM
Henson071
May 4, 2015 12:23 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
