Comp Cams 230/236 and Emissions ?
Old Jul 10, 2002 | 11:33 PM
N.W. LT4's Avatar
Question Comp Cams 230/236 and Emissions ?
I'm doing the install tomorrow and want to know if I can get this cam to pass emissions here in Wa. State
thanks
Old Jul 18, 2002 | 12:14 AM
ScLeCo's Avatar
Post
LMAO
I wouldn't bet on it, Im assuming you got headers, cats??
//BLACK 99 SS//M-6//T-Top//TR 224/224 .561/.561 112LSA//CNC Stage 2 Heads 2.08"Intake-1.60" Exhaust Valves//Volant Cold Air Induction//BBK 80mm Throttle Body//SLP Stage 1 Suspension Kit// Powerslut Rotors//Hawk Pads//Mosser 12 bolt-4.10 Gears//SPEC Stage 3 Clutch//ASP Underdrive Pulley//Lingenfelter Aluminum Driveshaft//BMR Sway Bars-Lower Controll Arms-Panhard Rod-Track Pak-Strut Tower Brace//Taylor Wires-NGK plugs//HPP 3-160 Stat//Skip Shift Eliminator//B&M Ripper Shifter//SLP LT Headers-SLP ORY No Cats//Borla Cat Back//Dynomax Bullit//ECT...
Old Jul 18, 2002 | 12:26 AM
N.W. LT4's Avatar
Post
LYAO huh. I'll keep you posted.
Old Jul 20, 2002 | 08:35 AM
RichJ's Avatar
Post
Don't listen to the guy above. He doesn't know what he's talking about. A 230/236 will easily pass emissions...
...with a 116 LSA!
Rich
Old Jul 21, 2002 | 01:17 PM
CanadianZ's Avatar
Post
I have heard of people being able to get a CC306 to pass and the XE 230/236 isn't too far off of that. You will need cats for sure and a special tune that you put on as soon as you pull up to the emissions place. The car will not be able to drive with the tune necessary to pass. (if it does)
CanadianZ
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
alliance12364
Mar 6, 2015 04:39 PM
