Code P1131 - I need help
Old Oct 22, 2005 | 11:25 PM
arnoli's Avatar
Question Code P1131 - I need help
If it is one of the O2 sensors, I have no clue which one is and is the Bosh O2 good? The car is only 22000 miles thats what surprises me.
Any input will be welcome..!
Arnoli
Old Oct 23, 2005 | 12:04 PM
2001NBMZ28's Avatar
Re: Code P1131 - I need help
You can look up DTC codes at www.obdii.com Are you sure it's P1131, and not P1133?
Old Oct 23, 2005 | 07:36 PM
arnoli's Avatar
Thanks for the input.
The code is correct.
I didn't see in which way the "AutoTap" web site can help me, because the link (www.obdii.com) goes straight to AutoTap people. What I saw there was too much text and less real info for specifique real problems.
The tuning had been done 8 month ago. Program used was LS1Edit.
The problem just start recentely.
AutoZone scanned it. They got "P1131 = Lack of HO2S Switch - Sensor Indicates Lean"
Old Oct 23, 2005 | 09:10 PM
moparman's Avatar
That refers to the after cat sensor on the driver's side.
Old Oct 24, 2005 | 03:28 PM
J. Baumgarner's Avatar
I agree with 2001NBMZ28. Are you sure that the code is not 1133. I don't believe that there is a 1131 code. A 1133 code is HO2S Insufficient Switching Bank 1 Sensor 1. (Drivers side). Check the code again. It has to be 1133.
Old Oct 24, 2005 | 04:15 PM
2001NBMZ28's Avatar
The reason I questioned the code was because when I looked it up on www.obdii.com/codes.asp it didn't look like an Fbody code - 1131 Circuit Low Varience B1, S2 (Engine C) only entry. One or two different numbers can make the difference between banks/sensors - just want you to identify the right one before replacing what might be the wrong sensor.
Old Oct 24, 2005 | 04:56 PM
Dave89IROC's Avatar
agreed, 1131 is not a f-body code
http://shbox.com/1/Dtcs.htm
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
