Code 42, how do I fix?
Old Aug 12, 2005 | 01:46 PM
flyinZ's Avatar
I keep gettin' the code 42, every since I installed a new Opti/coil/ICM.Itseems to be pulling timing 5* across the board. How do i fix this?? Install error? Faulty piece? Need help!
Old Aug 15, 2005 | 01:16 PM
flyinZ's Avatar
Re: Code 42, how do I fix?
Turns out that this code is an Opti code..Its missing a signal from the Opti, to the PCM..Either has to be either the Opti, or the pigtail harness....Anybody have this problem?
Old Aug 15, 2005 | 01:37 PM
DTC 42 = Ignition Control (IC) circuit (shorted or grounded circuit)
Not necessarily an "opti code"..... can be related to many components in the ignition system. It may set along with other codes for an Opti related problem, but is related to the signal from the PCM to the ICM being shorted out.
As a result, the factory manual includes a fairly complex diagnostic tree that allows you to step your way through the possible problems, eliminating them one at a time. You need to get a copy of that diagnostic chart and work your way through it. If you can't find it online, I could probably find a copy that I could fax to you.
Old Aug 16, 2005 | 08:12 AM
flyinZ's Avatar
Id appreciate it Fred.. I dont have a factory manual, never got one
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
Timberwolf
Aug 18, 2002 07:39 PM
91Bird305
Aug 5, 2002 01:39 PM
MislMan
Jul 19, 2002 11:41 AM
