code 18 (not in use?)
Old Aug 6, 2011 | 02:37 PM
85LT1Z28MEX's Avatar
any idea why i get this message in the code?
code 18 (not in use) so if not in use, why throw a code?
could be disabled in the pcm?
this is in my 96 ODBI z28. i used freeScan and Datamaster
i got the code, right after Install the ODBI pcm, deleted and came back. i am planning to drive the car for some time and check again. hope its not a big deal.
Old Aug 6, 2011 | 09:52 PM
Re: code 18 (not in use?)
First thing is that 18 is not even an OBD-II code. It is an OBD-I code. Freescan and Datamaster don't do OBD-II. You say 96 OBD-I. 96 is OBD-II. ...unless you converted to OBD-I...
Old Aug 8, 2011 | 09:53 AM
you are right, I am using ODBI pcm. I Did te conversion so I can use DM and FS.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
